Salta al contenuto principale
Model Number: wa50k8600av/a2 Stainless steel 5.0 cu. ft. top loading washing machine
Why am I getting code 9c8?
In the middle of spinning it started sounding ding and had code 9c8. I’ve already done update about fire recall. What now?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
It's a software update issue.
Press and hold the start button to clear the error code. then hold the Smart Control button for 3 seconds and then the temp button for 7 seconds. Then turn the machine off and back on.
Punteggio 1
11 Commenti:
That did not work
da
That did not work. I soregret buying this washer, is a junk
da
Did not fix issue
da
@brendamay70158 same make and model? What are the issues? What all have you tried?
da
I cannot find the smart control button.
da
Mostra altri 6 commenti
Preparati per le riparazioni future
Aggiungi la tua risposta
Pamela Smithey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 4,329
