Salta al contenuto principale
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
Pendrive does not showing in drive
I have hp 16gb pendrive. When I put in my laptop, the pendrive is not showing in drive , when i tried to open it the computer give me msg " insert a disk" ,also tried to put it in tv but same it was not opened,
how can I open it ?
Questa è una buona domanda?
Punteggio 0
2 Commenti
@dharapatel45173 What operating system are you running (e.g. Windows 10)?
da
operating system is Windows 10
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @dharapatel1 , sounds like it could be a failed drive unfortunately! This is a pretty common failure mode when the NAND flash stops being able to be written to. The controller still shows up, but its no longer able to communicate with the NAND memory. It might be time for a new drive. Thanks!
Punteggio 0
Parti e strumenti correlati
Aggiungi la tua risposta
Dhara Patel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 113
