Salta al contenuto principale
Lanciato a maggio 2020, il MacBook Pro da 13" ha dei processori quad-core Intel di ottava generazione Core i5 e i7, e grafica integrata Intel Iris Plus 645. (Modello A2289/EMC3456 con due porte Thunderbolt 3)
MacBook Pro A2289 Display Compatibility?
I've got an A2289 with a damaged display. Part number on the display is 820-02008-A and the EEE code is PXGV. Does anyone know what displays are compatible with this computer? I've heard that 2018-2020 Intel 13-inch displays are all interchangeable, but I've tried two separate good condition displays that I thought fell into that range (part numbers 820-02008-01 and 820-00452-A) and they both had dim backlights after logging in and the first one didn't register the camera. Any suggestions or links to reliable retailers online? Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@zp[ the 820-00452-A should belong to a 2016-2017 and it will not be compatible. Check on here for the parts number (look for the 661-xxxxx numbers and the compatibility with your system
Punteggio 1
1 Commento:
Thank you! I appreciate it.
da
Aggiungi la tua risposta
Zach sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 294
