Salta al contenuto principale
Dell Inspiron laptop with a 15.6" diagonal LCD display
Laptop does not turn on
The laptop does not turn on when the power adapter is connected to the laptop its led goes off
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
the battery might need replacement. tried a different power adapter?
Punteggio 0
1 Commento:
My laptop battery problem is from long time. But so long my laptop is running without battery but now it is not running
da
Hello @nii99203 , does it power on with the battery disconnected? If so, you may need a replacement battery. Also, as @carlotremolada said, it may be worth trying another power adapter to make sure!
Punteggio 0
1 Commento:
da
Yes led off. Orrange colour led blinking
Punteggio 0
Aggiungi la tua risposta
Nii sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 179
