Salta al contenuto principale
Processore quad core Intel Core i7 da 2,0. 2,3 o 2,6 GHz (fino a 3,8 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
Wi-Fi is not working and Bluetooth is
Hey.. my wifi doesn’t work on the computer. Shows a slash through it. Works when I first restart but then shuts off. Bluetooth still works. Is this spyware or a hardware issue? Sometimes when the wifi shuts off the entire computer freezes and shuts off and restarts.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
replace the wireless card
Punteggio 0
Try booting into safe mode. You can do this by holding shift when booting. (See https://support.apple.com/en-gb/guide/ma.... https://support.apple.com/en-gb/guide/ma.... For more) If that doesn’t work then you know it is not software and indeed a hardware issue. You can also check that the antenna lines are good, as they could be broken.
Hope you get this fixed.
Punteggio 0
Aggiungi la tua risposta
Crash Bandicoot sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 104
