Salta al contenuto principale
Device repair and troubleshooting for the Dell Inspiron 15 inch laptop computer with model number 3567.
Replacing DVD writer to SSD
How i can change the DVD writer to SSD sloat using caddy method, and which size of caddy are correct to use SSD.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The DELL Inspiron 15 DVD is 9.5 mm thick and most standard SATA SSD's are 7mm.
You will need a Universal 9.5mm SATA 2nd HDD/SSD Hard Drive Caddy For CD/DVD-ROM Optical Bay.
The SSD may need a little foam spacer.
Here is a video on how to remove the DVD
How to remove DVD
Punteggio 3
Aggiungi la tua risposta
Hritick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 198
