Salta al contenuto principale
Modello A1989, EMC 3358. Aggiornamento del modello esistente, con nuove opzioni per il processore e un cambiamento nei materiali della tastiera. Disponibile nei colori Argento e Grigio siderale. Rilasciato nel maggio 2019.
Why is it not turning on?
I was trying to remove a dead screen assembly and forgot to remove the battery screw for the first few screws. I remembered and in a little panic I tried to get my finger under the battery cable and accidentally pulled it out from the other end (the small side). I drained all power and removed the screen. The cable looked intact and where it plugs in looked fine so I opened it up and replugged it.When I first switched it on it came on no problem (was gonna use as a desktop until I bought a new screen assembly). So I restarted it to get it to send to an ext monitor an it hasn’t came back on. Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The lid has a function telling the logic board the lid is either open or closed! When you remove it you remove the input. If you look on the backside of the logic board you can see the two Hall Effect sensors MacBook Pro 13" Retina (2019) 2.4 GHz Logic Board with Paired Touch ID Sensor look at the left and right sides the little bump outs with a device that is standing proud is the sensor.
So in order for the displays signal to travel to the external the lid needs to be left on the system with the lid closed. Then using USB wired keyboard and mouse/trackpad you can use your system. If you can still gain access you might still be able to setup a Bluetooth keyboard and mouse/trackpad.
As far as that little cable that is the battery monitoring data cable which also needs to be present for the system to work properly. If you damaged the cable and/or the connectors that may require a new cable and if the connectors are damaged deeper skills to replace.
Immagine Replace a 2.4 GHz Core i5 logic board (motherboard) compatible with the MacBook Pro 13" Retina (2019). Includes 8 GB or 16 GB of RAM, paired Touch ID sensor, and SSD. Fix processing issues like unexpected shutdowns, reboots or water damage.
Prodotto
$299.99
Punteggio 0
Aggiungi la tua risposta
OldMate69 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 75
