Salta al contenuto principale
Realme C3 is a low budget Android smartphone developed by Realme. Released in February 2020 in India and March 2020 in the Philippines.
My speaker did not work properly
Questa è una buona domanda?
Punteggio 7
7 Commenti
da
Speaker saya tidak ada suara
da
Volume lower
da
Speaker rusak
da
@nurmanmila Check the original answer about the How-to replace the speaker.
Translate
Periksa jawaban asli tentang Cara mengganti speaker.
da
Mostra altri 2 commenti
Aggiungi un commento
2 Risposte
Risposta Più Utile
@akashsingh81633 you are not telling us what it sounds like or if anything happened to the phone prior to the speaker issue appearing.
First, I would suggest that you clean the speaker grille on the external phone. Make sure that it is clean. Of course, check all your audio settings as well to ensure proper sound playback. If none of that helps, you may consider replacing the speaker. Check on something like this video for more info.
Of course, you can replace the speaker. Since iFixit does not yet have a specific guide for that, use something like this video It will show you how to replace the speaker. Replacements are readily available at many online stores. Anything after that will most likely involve some board level repair and for that check on here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 2
Parti e strumenti correlati
Apne najdiki mobile repair shop par jao aur use mobile de dijiyega screen Jo tooti hui hai
Thik kar dega.
Translation Hindi-English
Go to your nearest mobile repair shop and give him the mobile with a broken screen.
Will fix it.
Punteggio 0
1 Commento:
@deepakkuma20739 people come here for advice on how to fix their device, not to be send to a repair shop. It is our goal to empower people to fix their own stuff. So, whenever it is possible we should always provide a helpful solution for the repair to the person that asks.
Translation
@deepakkumaa20739 log apane divais ko theek karane ke baare mein salaah lene ke lie yahaan aate hain, na ki kisee marammat kee dukaan par bheje jaane ke lie. logon ko apana saamaan svayan theek karane ke lie sashakt banaana hamaara lakshy hai. isalie, jab bhee sambhav ho hamen hamesha poochhane vaale vyakti ko marammat ke lie ek upayogee samaadhaan pradaan karana chaahie.
da
Aggiungi la tua risposta
Akash Singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,547
