Flashing Refrigator error code
what does failure code 8 E mean
Questa è una buona domanda?
The 8E error code on a Samsung refrigerator means that the ice maker sensor has likely failed. This error code indicates an issue with the defrost sensor, ice maker, ice pipe heater, ice fan, or compressor lock.
If you replaced the icemaker with the sensor, you can reset the error. To clear the error code, you can press and hold the upper left and middle left buttons for about 8 seconds.
Parti e strumenti popolari
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 42
Tutti i Tempi: 3,289
1 Commento
8E: Ice Maker (Freezer) Sensor Error. Try Samsung's site; https://www.samsung.com/us/support/troub...
da F Dryer
