Salta al contenuto principale
The Inspiron 15 3565 is a 15-inch budget laptop released by Dell around 2017 or 2018. It has both an AMD processor and an AMD graphics card.
I want to uograde the CPU and GPU
it uses the sane socket si maybe it is possible and i want to add dedicated GPU there is a slot for it then i might as well upgrade the cooling system..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@akiradokkabei have you opened your laptop up and checked the motherboard. It is my understanding that the CPU and GPU are soldered to the board. Sure it can be done, if you have the tools and the skills. Also, you need to make sure that your motherboard chipset supports a dedicated GPU. It's definitely not plug-and-play.
Punteggio 0
2 Commenti:
actually i am just doing this for fun...The board is pretty much cheap since its a trash APU.
da
@akiradokkabei I see. Well in that case you got a good board to practice some soldering skills :-) Not sure if you want to go ahead and waste a CPU or a GPU on a "trash APU"
da
Aggiungi la tua risposta
AKIRA Dokkabei sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 159
