Salta al contenuto principale
A Vornado circulator uses special airflow called Vortex Action to circulate all the air in the room. The air flows fast, cool and constant to create a cooling experience unlike any other.
3 Domande Visualizza tutte
How to clean accumulated dirt from the blades and interior
I need to figure out how to remove the front grill so I can clean accumulated pet hair/dust off blades and interior. It's so gross I will have to replace if I can't figure out how to clean Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There are three screws on the back of the fan. Remove those screws and you should be able to take the fan grill off. Once you get the grill off, clean it with water and a mild soap. Make sure the fan is unplugged while you clean it.
Punteggio 0
Aggiungi la tua risposta
Sarah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 28
Tutti i Tempi: 904
