Salta al contenuto principale
Toy quadcopter with camera, controlled over Wifi by smartphone.
What is the 3-Axis Accelerometer Specification / Part Number
The AR Drone breakdown is excellent, thank you. I have just one question.
Do you have the specification/part number for the 3-axis accelerometer which I presume is one of the components on the Navigation Board.
Many thanks
Mick (Masters Student)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
check this "For the inertial guidance system, ACAL recommended a Bosch BMA150 3-axis accelerometer which works in conjunction with a 2-axis gyrometer and a 1-axis yaw gyrometer to provide the data for the auto-pilot. Initially. the AR.Drone used a QFN-packaged accelerometer, but ACAL suggested migrating to the LGA-packaged BMA150. This reduced both the power consumption and cost," from here. the datasheet is available here. Just in case you need the navigation board, is is available at places like this. Hope this helps, good luck.
Punteggio 2
Preparati per le riparazioni future
Aggiungi la tua risposta
Mick Nadin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,602
