Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
Will not show anything on display after SSD replaced
I replaced the SSD in this iMac and now it will not show anything. The onboard LEDs 1 and 2 are on but there was no start up sound just the fan ramping up to full blast.
I already replaced the PSU and the motherboard, but it is still showing the same LEDs and no display.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you use the special pizza cutter to take the display off? Could you have damaged the displays cables?
Review our guide here Sostituzione schermo iMac 27" 2017
Punteggio 0
3 Commenti:
I did not use the pizza cutter tool. And I do not believe the cables were damaged.
I know the display worked after removing it because I was able to replace the HDD first test it out and both the display and replacement HDD worked fine. A day later after replacing the HDD I replaced the SSD too and that is when I had the issues with the iMac not fully turning on. I replaced the PSU and then got the onboard LEDs on. So thinking it was a video card issue I replaced the motherboard. Still having no display and now I do not know what to try.
da
@brettdowns36437 - I understand, well I think the display and/or the cable is damaged.
Ive had a few like this and after doing some voltage checks it was a damaged display as you can push the tool in too far.
But if you are so sure, how about removing the SSD to see what happens then.
da
@danj I tied with both the drives removed and still doing the same thing. I will order a screen and test it out. Honestly its the last thing I can try. Thank you for your help. Will post an update with the results. in about a week.
da
Parti e strumenti popolari
Acquista tutti
Aggiungi la tua risposta
Brett Downs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 43
