Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
How to remove a Forgotten Firmware Password
Hi there, I recently received a macbook air from a friend who didn’t want it anymore, there seems to be a firmware password on it that I don’t know, nor does he know it, I do have root and admin access on the macbook. How can I reset the password? All help would be appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check out this video. In order to reset the firmware password you would need to replace or reprogram the BIOS chip. This is a somewhat advanced procedure which requires special tools / skills. Good luck!
Punteggio 2
3 Commenti:
@zpl is there any other way to do this process or is this the only method, I apologize for the late response.
da
There are some tools you can use to interface with the board directly to reprogram the EFI chip, but they can be pretty hacky, so use caution! There isn't an easier way to remove a firmware password without the password.
da
@zpl ok, thanks, are there any that you recommend?
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
TechVid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 304
