noise coming from back
after changing rear shocks and link rod still have noise coming from left rear when brakes is applied . all brake pads was changed and serviced
Questa è una buona domanda?
Thanks but I found the problem to be the back seat locking mechanism and also a rod with bushing and ball joint was bad even when it was taken off it did not appear to be bad . I have no noise anymore.
Preparati per le riparazioni future
Brake Caliper might need to be looked at, seal might be defective
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 226
1 Commento
maybe one of the pads was installed backwards and you have metal to metal contact.
da CRD
