Salta al contenuto principale
Repair and disassembly information for Google's Pixel 6 smartphone, released in October 2021. Identified by model number GB7N6 and G9S9B16.
Why is the screen glitching when I make a call?
Hi! we changed the screen of my pixel 6 and now during a call the screen starts to glitch on and off and only seems to be steady if I put down the phone, also when I pick it up the screen does not turn on, has this happened to anyone? is it maybe the Proximity Sensor? Thanks for your help!
Questa è una buona domanda?
Punteggio 0
1 Commento
I cannot remove My 4 digit lock code. Can anyone please help.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Gabriela,
Owning a 6 Pro myself, I try to keep up on the issues my fellow Pixel owners are encountering, so I hope I can help.
By far the most common issue I've been seeing with screen replacements has been the problem of protective films being left in the various openings (both camera and proximity sensor). You can usually tell because looking carefully with a bright light, you'll see a tell-tale blue tint inside the opening. Here's an example of a Pixel 5a owner who had the same problem as you following a screen change.
Proximity sensor not working after new screen replacement - Google Pixel 5a - iFixit
Unfortunately we never got confirmation that was the issue but it would definitely be something to check.
Before you go through the trouble of opening up the phone again, you might go ahead and try the software remedies suggested by this article. Yes, it says its for a 6 Pro, but I don't see anything in the article that should be different for a 6.
How to Fix Pixel 6 Pro Proximity Sensor Issue
I did run across one other item that could be relevant; again you'll have to open up the phone to check it, but definitely something to look at in case the protective plastic theory doesn't pan out.
Pixel 6 Screen Replacement Proximity Sensor Issues : r/GooglePixel
Unfortunately, I can't seem to find any definitive information on the location of the 6's proximity sensor, but it's almost always at the top of the phone usually near the front camera. Hold the screen up to a bright light and you should see a peephole in there somewhere; that's where you need to check for protective plastic.
Punteggio 2
1 Commento:
Thank you! We will check the sensor!
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Gabriela VAZQUEZ M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 623
