Salta al contenuto principale
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
20 Domande Visualizza tutte
Why the passenger window will not work going up?
I have a 2010 Nissan Altima and the right passenger front window has stopped working from going up will it be a fuse still if it's just one window or would it be something else?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@needadvice it wouldn't be a fuse. The fuse would not care if the motor goes up or down, it protects the motor no matter which way it operates. Since your window goes down but not up, it's not the fuse. You want to check the switch first and then the actual motor. You will have to remove your door panel etc. WE need to know if this is a Altima Sedan or Coupe (2 or 4 door)
Here is the part from the service manual that deals with the power windows. It is quiet complex. We do not know your comfort level on working on this yourself, but it gives you an idea. It can be pretty involved but it is NOT rocket science. So, it's up to you ;-)
Power Window Control System (Section PWC)
Punteggio 0
Aggiungi la tua risposta
Need-Advice sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 380
