problem in the LB button
I accidentally dropped my Xbox 360 controller on the shelf. The LB button is loose. What do I do now?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Thiago Cristofolini, I suggest that you dismantle the controller and check for any broken or displaced parts. Use this guide to inspect your bumper panel. Hope this helps, and let us know what you find. Good Luck.
thank you I have not done the process but I thank
Thank you for accepting my answer. It is important to first properly identify the damaged parts, then it is a matter of obtaining the parts that are needed and a good guide to do the repair. All the best to you and let us know if you need further help. Good Luck.
What tools are needed?
Check the guide I linked to. It has a listing of the tools needed at the top of the page. It calls for a Spudger, T8 Torx Security Bit Screwdriver, and a pair of Tweezers.
You know, somewhere has to sell in Brazil? Because I am Brazilian.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,980
