Salta al contenuto principale
The Samsung Galaxy A7 (2017) is a mid-range smartphone in the Galaxy A series. It was unveiled by Samsung in January 2017 together with the Samsung Galaxy A3 (2017) and A5 (2017).
How to replace a shattered back glass?
My samsung is in pretty bad shape. Since the back glass is open and shattered, the water resistance capability is useless since it is opened like an egg. Can somebody help me with the repair it means a lot for me. Thank you very much.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Use something, hair dryer etc to heat up the adhesive around the frame and peel the back away. Clean up any remaining adhesive then fit a new adhesive and back.
Punteggio 2
5 Commenti:
Thanks a lot for the help! But I'm wondering if it is safe to submerge my phone in water for under water pictures. And I think when I'm installing the back glass I did a terrible job. Also I bought the back glass in lazada, it is an online store here in SE Asia. Should I add some extra adhesive to be water resistance?
da
@enricogabr24424 Absolutely not. Any water resistance that the phone is rated for is negated the moment the phone is opened. Even the best professional replacement cannot requalify the water resistance rating. Done correctly, your phone will be mostly waterproof and will probably survive exposure to water, but unless you want to be buying a new phone due to water damage, do not attempt underwater photos with a phone that's been compromised.
I'd suggest a waterproof pouch to put the phone in if you want to use it for underwater pictures.
da
@enricogabr24424 Never ever submerge a phone in water. I've had so called 'waterproof' phones come in for repair after water damage. If you want to take underwater pictures buy a go pro or a action camera.
da
Thanks for letting me know.
da
شكرا جزيلا لكم
da
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Enrico sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 349
