Salta al contenuto principale
The HP Envy x360 m6-aq103dx has touchscreen and 360° capability, which makes it a 2-in-1 for those that want a laptop and tablet in one device. Model number: W2K45UA.
Error Code on Caps Lock
Every now and then I would get this error code and it would go away and now it's constantly doing it.
Caps Lock Error:
3 Long
2 Short
I took the screen off to see any loose cables and there were none, also took the bottom cover to check and same result. I thought about changing the CMOS batter this board has but idk how to take that out. Any recommendations would be great.
Questa è una buona domanda?
Punteggio 0
1 Commento
The issue was one of my RAM sticks went bad. Thank you @flannelistt (Alisha C)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If I remember correctly, 3 long, 2 short is most likely a RAM issue for most HP models. In fact, blink codes in general are most often cleared on laptops by a simple reseat of your RAM.
That seems to coincide with your “every now and then” sort of experience. Maybe one of the sticks is just loose.
If you confirm the exact model number of the machine, we can probably confirm this and get some service documentation. But I would pop off the bottom off the laptop, unplug the battery (the regular one, not the CMOS one), then pull your RAM stick(s) out, then put them back in and see if you’re in business.
Punteggio 2
5 Commenti:
HP Envy x360 m6-aq103dx as it says on the back.
da
@xfuskyx Just making sure, with Windows machines, there are so many I always want to be certain. The Service Manual will give you the rundown on how to get the unit open, how to disconnect the battery, the RAM, even the CMOS battery if you wanted to give that a try.
da
Thank you, I'll give this a try and update you.
da
Ended up being one of the RAM sticks. Thank you.
da
@xfuskyx My pleasure. Glad it was an easy fix!
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Bryan Fuscarino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 849
