Salta al contenuto principale
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
How to re-solder usb cable
i found out that my galaxy tab's (7" P1000) usb cable was cut off at the USB extremity (the one that goes into the PC or Charger, not the one that goes to the GTab).
And to fix it i need to know the right order to solder the wires to the usb extremity; i have blue, red, white, and green wires that goes to 4 soldering point.
i hope you understood my problem and will help me fix it,
Thanks
Questa è una buona domanda?
Punteggio 3
2 Commenti
So i have found this about USB 2.0 Wikipedia USB
So i wanted to know if i can use the same order as in TYPE 1 USB but using the blue wire instead of the Black one for GND.
i hope i was clear enough
da
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
So i was right it's the same order as the standard USB 2 with the blue wire as GND instead of the black one.
So it's Solved
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Trabajando con los puntos de soldadura del lado derecho del puerto USB el orden es el siguiente, de arriba hacia abajo: BLANCO, ROJO, VERDE, NEGRO.
blanco
rojo
verde
negro.
Punteggio 0
Aggiungi la tua risposta
Samy Chaabna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 9,600
