Salta al contenuto principale
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
Punteggio 0
6 Commenti:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
da
@charles218 yup. Right one the power lead.
da
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
da
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
da
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
da
Mostra 1 altro commento
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Charles Larkins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 134
