Salta al contenuto principale
Informazioni sulla riparazione e lo smontaggio per lo smartphone Pixel 6 Pro di Google, lanciato sul mercato a ottobre 2021. Identificato dai numeri di modello GLUOG e G8VOU.
Where to Find a Replecement Power Button
P6P power button has recently fallen out twice. Luckily, I found the loose button in my pocket, but I may not always be so lucky. Looking for a place to buy replacement power buttons.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Ronnie,
I have to admit I didn't have any luck finding anyone in my usual sources who sells just the physical buttons themselves. The closest I came was a Reddit post where a guy ended up taking a chance and buying the buttons for a Pixel 7 to replace a missing one on his 6 Pro and reported that the button fit perfectly. Unfortunately he was talking about a volume button rather than the power button, so it's not really an answer, more of a lead. Here's the thread.
Pixel 6 Pro Volume Button Fell Off : GooglePixel
And here's a link to the eBay listing that appears to still be good.
For Google Pixel 7 7Pro Pro Side Button Keys Power Volume Buttons Replacement
That's the closest I can come; let us know what you end up doing, as I'm invested in the subject since I have a 6 Pro myself.
Punteggio 2
1 Commento:
Thank you for the link, Jerry. I'm going to spring for the $10 US and take a chance that the power button may also be compatible with the P6 Pro.
It ships from China, so it will be a few weeks until it arrives here in Los Angeles. I'll definitely keep you posted after I try it, regardless of the result.
I see several posts about these buttons falling off, on both the P6 and P7 series. So, I don't understand why these simple replaceable parts are not readily available. I guess that the "Right to Repair" law here in the US has no clout, since Google seems unwilling to make the parts available, even for purchase.
da
Preparati per le riparazioni future
Acquista tutti
I received the set of Pixel 7 Pro power and volume buttons from that eBay seller today. As best as I can tell, both the power button and the volume buttons appear to be the same length as those on my Pixel 6 Pro. They seem to be slightly narrower, but I don't think that will be a problem. It appears that there was a mistake in packaging because the volume button is gold, which is correct for my Sorta Sunny color, but the power button is silver. Again, not a big problem.
However, since my power button has only fallen off twice, and it seems to be holding up for quite a while now, I decided not to install it until/unless it falls off again by itself. I'm afraid of wear on the inner plastic tabs by forcibly removing the button. So, although I can't confirm for certain that these replacements will fit properly, it looks promising.
Punteggio 0
Aggiungi la tua risposta
Ronnie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 125
Tutti i Tempi: 3,379
