Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
How to remove dust from the speaker?
The sound is bad as if there was object on the membrane
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
More likely the membrane is torn which over time happens. Using the speaker balance control see if you can ID which speaker is bad it’s also possible both are needed. Here’s the parts Speakers
Punteggio 2
1 Commento:
Thank you Dan, I'm gonna check the part number on my computer and order it as both speakers are effectively bad.
da
Aggiungi la tua risposta
Destouches sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 73
