Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
What are these components?
Hi,
I have this MacBook Pro that does not let me install an operating system, I have tried multiple versions of MacOS, Windows and Linux however all of these froze during installation and would not complete.
On the odd occasion I was able to get the progress bar for MacOS to 100% but it would not budge after that.
I have tried all the typical solutions to this problem (resetting SMC/Nvram, disabling the dedicated gpu, e.t.c.) however none of these methods proved effective.
On closer inspection of the logic board, I found that these 2 components (pictures) appear to have their connection to the logic board damaged. I would like to know what those components are and what they are responsible for in the device. Could they be the source of my issue?
Any help is greatly appreciated! : )
Thanks
Pictures:
https://guide-images.cdn.ifixit.com/igi/...
Questa è una buona domanda?
Punteggio 0
4 Commenti:
@computerashes those are both 0.36µH 26A 1.05mOhm Inductors in a MPCG1040 package. They are critical components for your CPU Vcore regulator circuit.
da
@computerashes did you ever fix those inductors?
da
@oldturkey03 well a slightly more capable soldering iron arrived yesterday so I am planning on retouching the connections
da
@computerashes okay sounds like a plan
da
Aggiungi un commento
1 Risposta
You likely have a simple problem! Let’s get a bit more info what is the amount of RAM you have installed and what drive are you using kind HDD or SSD AND its Make & Model.
Punteggio 0
22 Commenti:
I have 2GB of RAM installed in one slot as the other slot appears to be faulty as well as a 500GB Seagate HDD (I don't know where to find which model it is) The HDD has been pulled from another fully working Mac
da
@computerashes - 2GB is quite lean. I would put in a 4GB module. For the drive take a picture of the drive labels and post them here.
da
@danj Here is a picture of the drive label: https://cdn.discordapp.com/attachments/1...
I am hesitant to add a 4GB stick as I am running low on thermal paste to put the device back together and I do believe that it is a board level issue - I have a few MacBook's from the same era who run fine on 2GB of ram.
da
@computerashes From your pictures I would say that the components, whatever they are, appear to be intact. It looks to me like a couple of the solder joints have come apart; if it was mine I'd try touching them both up with a soldering iron to resecure the connection then see if it makes any difference.
da
@dadibrokeit That was my initial plan however I thought I'd ask what purpose they serve and if they are at all linked to the Kernel as it does occasionally Kernel panic.
da
Mostra altri 17 commenti
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Computer Ashes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 259
