Salta al contenuto principale
Cursor stuck in the upper left corner
I just replaced the logic board and optical drive and when I boot up the mouse pad does not work. What should I check 1st?
Update
The built in track pad is not working. I am checking the connection now. I was hoping to find out which connection is the likely problem.
thanks for the help
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Do you mean you're running a USB mouse or the in-built trackpad on the keyboard area? If it's USB the check ports externally for dirt/bent pins and for solder crack internally. If it's the trackpad and you had no previous prioblems then you should recheck your connection there.
Punteggio 4
1 Commento:
Reseat the keyboard connector making sure you haven't bent over any pins on the connector: PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard Replacement
da
Parti e strumenti popolari
Acquista tutti
The 4 pins are straight and connector seems fine. Yet no track pad working yet.
USB mouse does work.
Punteggio 0
Aggiungi la tua risposta
John SS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 704
