Salta al contenuto principale
The Galaxy J6, released in 2018, is the successor to the Galaxy J5.
My touch does not work anymore
My mobile samsung j6 had fallen down from my bed to a distance of 2 metres. From then my touch is not working,
but there is no crack on the screen due to it.
It is working as perfectly as it can when I connect it to USB mouse or keyboard.
Is there any way I can retain my touch back without replacing a part?
(OR)
Is there any way I can retain my touch back by replacing a part and what part it can be and where can I get it?
(Even the smallest answer would be greatly helpful to me.)
Questa è una buona domanda?
Punteggio 3
1 Commento
My phone has follen down but no crack and and the screen also glowing but touch is not working
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hemasai Duppalapudi sounds like your touchscreen got cracked. Yes, there is a possibility that it is a loose connection on the main board but chances of that happening is slim. You will have to replace the display assembly, which includes your touchscreen. Use something like this video or even this Samsung Galaxy J6 Display Replacement as your guide. Replacement screens are readily available and prices are reasonable.
Punteggio 3
2 Commenti:
My phone touch was not working
da
@samsung18678 same answer for your phone!
da
Preparati per le riparazioni future
hp lama saya suka nge lag. sentuhannya butuh waktu beberapa menit. buka apk yang menggunakan internet,tidak bisa. padahal penyimpanan masih banyak
Translate Indonesian - English
My old cellphone likes to lag. the touch took a few minutes. open the apk that uses the internet, can't. even though there is still a lot of storage
Punteggio 0
1 Commento:
@bili74026 make and mode for your phone?
@bili74026 merek dan mode ponsel Anda?
da
Aggiungi la tua risposta
Hemasai Duppalapudi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 832
