Salta al contenuto principale
Repair guides and support for smartphones manufactured by Doogee.
Trying to get the screen out to replace charging port
My Doogee S59 Pro's charging port was broken by a cheap type C charger, and it has glue all around the screen, which I need to remove to access the Charging board. Does anyone know of something that will dissolve the glue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Heat! Just apply heat (100C) around the screen for 8 to 10 minutes, then pry on it (gently). I've been trying to get it out for months then saw this video! https://youtu.be/LM5Qae_A5oU
Punteggio 1
1 Commento:
hi there, i have the same problem, did you finally replace the charging port ?
da
Aggiungi la tua risposta
Anchevauls Walker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 26
Tutti i Tempi: 474
