Salta al contenuto principale
The Beats Studio3 was released in September 2017. There is no wired-only version of the Studio3 Wireless, however, it does include a 3.5 mm audio input port and a black RemoteTalk Cable for optional wired operation.
Is the Bluetooth board interchangeable
Can you use the Bluetooth board in the studio 2 to get Apple w1 chip in the better colors headphones
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
Unfortunately I don’t thing doing a board swap is possible because there are lots of small wires and they could all go to different places on the boards,there could also be extra cable in there too;-{
However
If you wanted you could take them apart and see if you could jerryrig some of the parts to fit together (some might need some things cut off on the inside in order for them to fit)as the plastic pieces on the studio 2 and 3 are very similar
Hopefully this helps
Any questions please ask
Punteggio 1
2 Commenti:
Thanks I will see if I’m that adventurous when I get my new battery for my headphones
da
@Dave Hall
Sounds like a plan!
da
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
Dave Hall sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 289
