Salta al contenuto principale
The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
6 Domande Visualizza tutte
Camera len don't come out
I press on the lens while it was working then the lens doesn't show up
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
LAETH ATHER_81 you can try and fix it first by moving the lens from side to side. It is possible that there is grime/grit/dust/sand in between the lens mechanism. Look at the lens and check it against the lens ring. See if is centered or if it is off center. If it is off-center, a little push on the side that is higher may make a difference. For some really useful tips on this, check on here. I've used a shopvac on a lens before, to assist it with extending. If nothing gets this resolved, you may have to consider replacing the lens.
Punteggio 1
Try to take a flathead screwdriver and pry the lens up.
Punteggio 0
Aggiungi la tua risposta
LAETH ATHER_81 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 249
