Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
constant restore loop after logic board replace
after replacing the logic board the iPod boots to a white screen asking you to connect to iTunes and Restore. iTunes fails during the restore due to error 1416/1415. This happens in both Windows and Mac OS X (tried tiger, leopard and snow).
When I look at the partition via pdisk, it says that there is no valid block 1 on the device.
Do I have a bad hard disk or is there another fix I'm missing.
Richard
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try unplugging all USB devices other than the iPod cable, keyboard and mouse. Sometimes when trying to do a restore other USB devices can interfere in the process. I that doesn't work then you should try to take it apart and replug all of the cables to make sure they all have a good connection. If that still doesn't work then it probably has a hardware problem. That would mean either the logic board, hard drive or possibly even the hard drive cable.
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
Richard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,723
