Salta al contenuto principale
La macchina per caffè De'Longhi BCO430 è un sistema combinato con pompa per espresso e macchina per caffè americano da 10 tazze, dotata di lancia vapore, nei colori argento e nero.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Immagine
Immagine
Immagine
Did these images come ok?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Risposta più utile
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
Punteggio 1
8 Commenti:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
da Condividi
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Aggiungere immagini ad una domanda
da Condividi
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
da Condividi
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
da Condividi
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
da Condividi
Mostra 3 altri commenti
These coffee makers often are similar. Compare to Rimozione del boiler della Saeco Magic Cappuccino SIN017 and Starbucks barista , perhaps it helps. Good luck!
Immagine Starbucks Barista
Guida
Smontaggio Starbucks Barista
Difficoltà:
Moderato
Immagine Saeco Magic Capuccino SIN017 Rimozione del boiler
Guida
Difficoltà:
Moderato
Punteggio 1
Pics attached - this is how far I could get
Update (10/08/2022)
Punteggio 0
Update (10/08/2022)
Immagine
Immagine
Immagine
Punteggio 0
Aggiungi la tua risposta
liluet_hernandez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 25
Tutti i Tempi: 517
