Salta al contenuto principale
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
replace PATA optical drive with an SSD drive
last night I had a crazy idea!
would it be possible to replace optical drive (PATA)
with an SSD drive?
the only problem is the PATA connection instead of SATA, I don't know if there is an adapter or PATA SSDs
edit: I found this:
[ http://eshop.macsales.com/item/OWC/SSDMX...|OWC Mercury EXTREME Pro Legacy Edition 9.5mm for IDE/ATA desktop systems]
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here's what you need to put in a SATA hard drive in your PATA optical bay slot: [prodotto collegato mancante o disabilitato: IF107-078]
Punteggio 5
4 Commenti:
from the notes on the link: This enclosure does not work with ATA drives or hard drives thicker than 9.5 mm.
plus: Compatibility >> MacBooks
da
again on the notes: This enclosure does not work with ATA drives or drives taller than 9.5mm.
which I don't understand why! PATA drives have different sizes?
da
Parti & Attrezzi Popolari
Acquista tutti
ok finally I can answer to my own question!
this a Caddy for this type of iMac. It converts Sata (internal) to Pata (external) you can use any data connection 2,5" drive (ssd or hdd).
here is the site selling it:
http://www.newmodeus.com/shop/index.php?...
Punteggio 1
Aggiungi la tua risposta
joleisa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,897
