Salta al contenuto principale
rapid clicking while trying to start
I replaced my starter and also solenoid and I still have rapid clicking while trying to start my cub cadet xt1. All terminals are clean and tight. Any suggestions on what else I can check.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
So that clicking is from the starter solenoid
Since the cables are fine and you replaced the starter, all I can think of is the battery. If you have a voltage meter, check to see if the battery is at 12.6. If it's not, let it charge overnight and try starting the mower again
Punteggio 0
1 Commento:
Mine is doing the exact same. Changed the starter, solenoid and battery. All wires are good and connections are good as well
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
PRESIDENT 4254 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 493
