Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
Are Keycaps replaceable on this model?
Are the keycaps replaceable on this model without opening the laptop and if so, are they available through iFIXIT?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
They theoretically are but it is very tricky to remove them and a high chance of them breaking. iFixit does not stock them sadly.
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
The key caps are in fact replaceable. The mechanism can be a bit delicate, but if you know where damage can occur it’s definitely avoidable. I can give further instructions if necessary, but didn’t want to clutter my response if you don’t end up needing to know.
There is also a known keyboard issue with this type of keyboard switch, so if you’re looking to replace them because they are stuck, not responsive , or a host of other issues I would look into this. As long as it has been less than 4 years from the date of original purchase you should be able to get free keycap replacement at the least. But more likely a replacement for the entire keyboard assembly.
Punteggio 1
Aggiungi la tua risposta
Tom Morin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 129
