Salta al contenuto principale
Documentazione per la riparazione del controller Dualsense utilizzato con la console Sony PlayStation 5. Numero modello CFI-ZCT1W. FCC ID: AK8CFIZCT1
L2 Button constant on even if not pushed
Hello,
i changed the two rings around the L3 button which caused stick drift , after getting all stuff together my L2 Button is like always enabled even if im not pushing it at all. How can i fix this ? Thanks
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Risposta Più Utile
Try taking the controller apart again and then push the L2 button then release. If that doesn't work ,try replacing the trigger button. Hope this helps!
Diode
Punteggio 1
3 Commenti:
tested some stuff and the L2 is even activated after i removed the left L1 and L2 unit from motherboard. So its something with the board i assume.
da
@Toni Montana Seems that way. All right. I don't know if I can help you in any other way. Sorry.
da
its a problem with the blue flat cable that connects the unit to the main board… try straightening the metals at the tip… worked for me
da
Usually it happens when the board is loose. There's one screw that atach the board to the controller shell. Open the controller again and Make sure you've tightened it.
Punteggio 0
when I had close to the same problem, I had to replace the spring on the side of the trigger. Also, I completely disassembled and clean the adaptive trigger with contact cleaner bw-100, but the spring was my real problem.
Punteggio 0
The small white ribbon cable that connects the trigger rumble pack to the board if you look very closely at the blue tab end you'll notice the gold connection lines, these are very thin and can bend easily, get a new ribbon cable or try to straighten it and trial and error it until it works (keep the casing off and try a game like astrobot until it's satisfactory)
Punteggio 0
Aggiungi la tua risposta
Toni Montana sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 74
Ultimi 30 Giorni: 376
Tutti i Tempi: 17,023
