Salta al contenuto principale
Il Samsung Galaxy A10s è uno smartphone Android sviluppato da Samsung Electronics, rilasciato nel marzo 2019.
Sim card network problem
My samsung a10s just swim through water and its sim not just working any more.
Questa è una buona domanda?
Punteggio 4
2 Commenti
Wi fi e buetooth
da
My samsung's is having internet connection problem
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi,
Did you remove the SIM card and dry it?
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video for the phone that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Punteggio 1
1 Commento:
Charging problem
da
Aggiungi la tua risposta
Bikalpa Dhakal sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 1,299
