Salta al contenuto principale
Informazioni di riparazione e soluzione problemi per l'HP Pavilion dv6000, un portatile HP facente parte della serie HP Pavilion. Rilasciato nell'aprile 2007.
Can I open without Charger?
I have an old Hp pavilion dv6000 Laptop I haven't opened it for 4 years and when I found it I didn't find the charger
So, is there a way to open it or Charger it without charger because I can't buy one
If any one can help me please answer
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi,
After 4 years without being charged, most probably the battery has become depleted beyond recovery and would need to be replaced.
You could get a replacement battery but most probably it would need to be charged so you would need a charger to do this.
If you only got a charger, you may be able to use the laptop by removing the battery from the laptop and running it on the charger only.
Search online for 693715-001 to find suppliers that suit you best.
Punteggio 1
Aggiungi la tua risposta
Eyad Ahmed sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 295
