Salta al contenuto principale
help did I get scammed?
So i bought this thinking i could fix one of my other ones,
Anyway when it arrived, i plugged it in and nothing,
I thought something was unplugged inside, so I took it Apart nothing was unplugged,
So i tried the keyboard on one of my other laptops, still nothing Nothing
What the heck is going on?
@danj
Questa è una buona domanda?
Punteggio 0
2 Commenti
What does the onboard battery checker tell you?
da
@danj - By nothing i mean it does nothing at all (black screen, no lights, no fan speed)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is a onboard battery checker within the battery. locate the LED's and the small button on the battery. What do you get?
The charger plug also has a Green or Amber lit collar. Is it lit and what is the color?
If both are dead then you will need to get replacements to check things.
Punteggio 1
20 Commenti:
I got no battery,
The charger has a green light
da
@beanman56 - OK, this series needs a battery to run. I would also replace the PRAM battery MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement But how much are you willing to put into this system? What is your expectation?
da
@danj - A decent macbook for media,
Also i like the keyboard design,
Would a 2007 macbook (NOT PRO) battery work?
idc if the matches
da
@beanman56 - Sorry no
da
@danj - where can i get one for a cheap price?
da
Mostra altri 15 commenti
Aggiungi la tua risposta
Ben Capehart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 207
