Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Switching processor from i3 to i7
Hi there!
If i upgrade my iMac from i3 processor to the i7 one (870 socket 1156) i read somewhere thay this could hurt my powersupply or graphics card, is that the case? Or can i just go ahead?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
As long as your iMac has the 305W PSU, it should work. It’s the same board between the i3 and i7 models so there should not be an EFI limitation.
Punteggio 1
2 Commenti:
Thanks for the answer, where can I see what PSU it has? :)
da
Make sure you get the correct CPU: 2.93 GHz Core i7 (I7-870)
Apple only used one version of power supply in this series: 310W
da
Parti e strumenti popolari
Acquista tutti
Aggiungi la tua risposta
Andreas Bohman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 88
