Salta al contenuto principale
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
I need help please...
Hi my 2005 chevy equinox is making like a low rattling noise while idling on park.its kind of annoying i just did an inspectiin and passed. If i hit the gas it goes away but while idling it does it what can it be? Please help other than that the car working wonderful. I had just changed all my mount, oil pan gasket, changed oil, did a tune up changed the breaks and ran it thru diagnostic no codes. Don't know what else to do.
Questa è una buona domanda?
Punteggio 0
1 Commento:
usually when you add a higher RPM noises tend to go away or get quieter.
you said you changed all your mounts? do you mean motor mounts?
i would get it up in the air and double check everything you touched or take it back to the shop you had it at and have them verify tightness all around.
da
Aggiungi un commento
1 Risposta
sounds like you disconnected something and forgot to reattach. Retrace your step as if you were going to perform the work again. I assume you removed the motor mounts to change the oil pan gasket. did you unhook the exhaust? It often has a heat shield of thin metal that might product a ‘rattling’ if not reattached.
Punteggio 0
Parti e strumenti correlati
Aggiungi la tua risposta
Milagros Rivera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 116
