Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
identify damaged SMD component
Hello everyone,
my Nintendo Switch sufferd by the flood in Germany this Year.
I try to repair the Joy cons. Because the Accupackage was still under Voltage a SMD component(I guess its a capacitator) sufferd from the electrocorrosion.
I cant measure its value anymore, so maybe someone can help me with this
Its in the lower left corner, maybe a boost capacitator.
Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That’s a coil not a capacitor, it’s should have continuity from 1 side to the other like a fuse but it shouldn’t short to ground.
Punteggio 2
2 Commenti:
Ok thats a good info, do you know its value?
da
@wasserollum I’m not sure but it looks similar to the switch lite backlight coil
da
Parti e strumenti popolari
Acquista tutti
Aggiungi la tua risposta
Oliver sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 184
