Salta al contenuto principale
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
How do you fix the headset jack
The port itself is broken, how do you replace it? This is a Razer Blade 15 Mercury White.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@largesushi that jack is soldered to the motherboard. So, if you want to replace it, you will have to remove the motherboard first. Use something like this guide to do so. Now you have to unsolder the old port and replace it with a new one. The problem you might be run into is finding a proper replacement. You can always check places like mouser. com, digikey.com or Jameco.com as well as others for a part that might fit. Ultimately its a lot of work but it can be done. May be you want to consider a USB audio adapter to use for your Razer Blade.
Punteggio 1
Aggiungi la tua risposta
Largesushi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 749
