Salta al contenuto principale
La versione con solo il Wi-Fi dell' Apple iPad Air, numero modello A1474. Disponibile nei colori grigio siderale e argento, ha un processore A7 custom ed è disponibile con memoria da 16, 32, 64 o 128 GB.
Not displaying correctly after replacing digitiser
Hi. I have replaced digitiser, and before securing screws and sticking down I switched on to test. All seemed to be working perfectly so I went ahead, but after securing I had a problem with screen. I had a line across middle where everything above was perfectly positioned, but everything below was slightly too high. This meant I had party of notification bar repeated on bottom and Several rows of image missing in middle.
I opened up again to check everything connected properly, but have caused more problems. Image is repeated and jumping up and down screen, now cannot get past home screen. I think I may have neglected to disconnect battery the second time around and am now concerned I have damaged LCD.
What is the most likely cause of this?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
While it is hard to say the exact issue without seeing a picture of the problem, based on past experience I would be inclined to believe that the LCD was slightly cracked or damaged during the repair. You will likely need to replace it.
Punteggio 0
3 Commenti:
Thanks for your time in replying Ben. I have edited to include video, but doesn't seem to be showing.
Do you think the first issue was LCD, or could that be a faulty digitiser? I am wondering whether to order an LCD panel with another digitiser, or just the panel?
da
@mclarenchris Based on the videos you uploaded I would expect that the digitizer should be fine, problem likely lies with the LCD. I would start with that and if it solves the problem, then you won't have spent unneeded money on parts.
da
Thanks Ben, appreciate the advice ?.
da
Aggiungi la tua risposta
Chris Reader sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 67
