Salta al contenuto principale
Released in 2008. Will have model number KDL-52W4100 the bottom right corner on the front.
3 Domande Visualizza tutte
intermittent horizontal lines on bottom quarter of screen
Sony KDL55W65: Getting intermittent horizontal lines on bottom quarter of screen. 2 seconds of lines, then 2 seconds of normal. Maybe a loose connection? Repairable?
This is a Sony KDL55W65. I chose Sony KDL-52W4100 because it was the closest option.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
loose connection possible. But a loose connection would not repeat an on/off cycle 2 on/ 2 off………..
each section of the screen is driven separately. It sounds like the circuitry for that section has a problem.
It is probably fixable by replacing the driver board for that section (though the board may include all sections). You need to look at whether it is worth the part and time/effort. The part might be used (cheaper) and the rest of the TV my have a smoldering problem (bad capacitors). There is no warranty on anything. New TV will have some kind of warranty.
There may be a Sony specific community forum that will have the exact problem and more info.
Punteggio 1
1 Commento:
This is helpful - thank you very much, Bill
da
Aggiungi la tua risposta
Phil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 233
