Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
How to install macos
I’ve tried multiple times to install macOS any version of really I’ve tried the apple conventional ways and I keep getting the same error saying that the macOS lion isn’t available trough the AppStore I’ve tried to install it with a USB but the computer will only let me boot trough internet recovery can anybody help ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your system can support macOS High Sierra (10.13.6) which is the highest OS supported.
To get it you’ll need to get the OS installer from here How to get old versions of macOS. You’ll need to create a bootable OS installer from another Mac system following this guide How to create a bootable macOS High Sierra installer drive
Then boot up using it using the Option (⌥) key to get to the Startup Manager so you can select it as the boot drive
Reference: Mac startup key combinations
Punteggio 1
6 Commenti:
What can I do if i don’t have another Mac?
da
@hakarou321 - Is your system booting up at all with the OS it has?
da
Nothing when it boots I just get a folder on the screen or I can try booting to internet recovery
da
@hakarou321 - See if Option-Command-R works or Shift-Option-Command-R
Reference: How to reinstall macOS
da
They all lead me to internet recovery and I can’t seem to install macOS x lion again it says « The Item is temporarily unavailable, try again later »
da
Mostra 1 altro commento
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
hakarou321 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 158
