Salta al contenuto principale
Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
How do you replace the hinge on Samsung Chromebook Plus V2?
It’s fairly easy to remove the display assembly, and then removing the trim piece across the bottom of the display reveals the hinges, but the hinge screws are obscured by the glass. Is it possible to remove and replace them?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
You're pretty much better off replacing the whole display assembly now, since the grade A OEM parts are not that expensive anymore. Also, it would be hard to find the hinge itself as a replacement.
Punteggio 0
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 114
