Salta al contenuto principale
Guide per il supporto e la riparazione del Huawei P9 Lite, rilasciato nell’aprile 2016.
Stuck at 0 precent
I had this phone for some time. I lost it 2 years ago and now I found it.
The only problem is… When I try to charge it it just gets stuck at 0% and won’t let me past that. I don’t know what is with it. Any help woud be apreciated
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @mrhidden ,
After two years of non use and non charging, most probably the battery has become depleted beyond recovery and has failed.
Try replacing the battery and then check if the phone charges and works OK.
Here’s the ifixit Sostituzione batteria Huawei P9 Lite guide that may help with this.
Replacement batteries are available online. Just search for Huawei P9 Lite battery to get results for suppliers that suit you.
Punteggio 1
Aggiungi la tua risposta
Raven Lartz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 25
Tutti i Tempi: 2,599
