Salta al contenuto principale
Il controller wireless Xbox One modello 1698 è stato rilasciato da Microsoft nel 2015 insieme al controller modello 1697. Questo controller è simile al modello 1697, con alcune modifiche interne. Presenta più funzionalità rispetto a un controller di base, come joystick rimovibili e tasti D-Pad in metallo. Il controller è progettato principalmente per l'uso con console, ma è compatibile con PC.
Why does the right trigger activate without touching it
My brothers controller recently started to get the right trigger problem where it would constantly activate but the left trigger wouldn’t work is there anything that my brother and I can fix this problem.
Questa è una buona domanda?
Punteggio 1
1 Commento:
My RT and LT buttons press themselves and RB is acting like the start button. Also my right stick isn't doing anything. The ABXY buttons work perfectly fine though.
da
Aggiungi un commento
1 Risposta
I've had controllers do this before. A sign that it's taking to much physical wear. Usually, a controller will do that when its hardware is resting on the internal components. Or the “middle man” component isnt doing its job because it is broken/worn or out of place. The only way to know would be to take it apart. Look for an internal part that gives the trigger resistance so it isnt ever resting on the internal button after you have applied pressure. Then see if it's the trigger itself by taking off the front controller plate and seeing if the button makes contact with the necessary button. If so, check the internal buttons to see if they are stuck or in a bind. Press them a few times and see if the console receives signal. Make sure everything is secure and safely reassembled.
Punteggio 0
Aggiungi la tua risposta
Andrew Urquizo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 3,539
