Screen replacement without changing top assembly
Hello, can the screen be replaced without changing the entire top assembly? I mean, can you replace jus tthe lcd screen?
Questa è una buona domanda?
I’ve recently replaced a display on an inspiron 13. I forget the specific model. If it’s anything like that which it looks like it should be. Yes you can. You’ll have to remove the display from the main body of the laptop. After that you should be able to use a pry tool to carefully separate the halves of the display housing. after that it’s just a few screws to remove the display. If you do this yourself just triple check and triple check again that you’ve ordered the proper display.
Parti e strumenti correlati
Acquista tuttiDavid, this is a long shot but where did you end up purchasing your screen from? I am in search of a 13.3" FHD screen replacement for my XPS 9370 and I can't find a reputable source.
I have the non-touch variant for reference.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 701
